はじめに
Use this guide to learn how to replace the headphone jack at the top of the back of the phone
必要な工具と部品
Power off your phone.
Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
Press the single suction cup just above the home button.
While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
Remove the 1mm screw concealed in the headphone jack.
Afterwards the headphone jack will easily pop off.
2 の人々がこのガイドを完成させました。
