メインコンテンツにスキップ
Amazon Fire Phone Battery Replacement
必要な工具と部品
  1. Amazon Fire Phone Battery Replacement, Tape the screen: 手順 1、 1の画像 1
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 手順 2、 3の画像 1 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 手順 2、 3の画像 2 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 手順 2、 3の画像 3
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Battery Replacement: 手順 3、 3の画像 1 Amazon Fire Phone Battery Replacement: 手順 3、 3の画像 2 Amazon Fire Phone Battery Replacement: 手順 3、 3の画像 3
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Battery Replacement, Remove Bracket: 手順 4、 1の画像 1
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
  5. Amazon Fire Phone Battery Replacement, Disconnect Battery: 手順 5、 1の画像 1
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
終わりに
21 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Lissandra Ilcyn
メンバー登録日: 10/05/15
841 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S5G7
5 メンバー
10のガイドは作成済み
14 件のコメント
Tolle Anleitung DANKE!!
Leo Henn - 返信
The replacement went exactly as presented. My stock battery had pull tabs to release the adhesive, making removal very easy. Thanks for a clear step-by-step guide.
John - 返信
How to bay amazone fire fone battry in pakistan
Manzoor Khan - 返信
where can i get fire phone battery in india
Shiva Sai - 返信
where can i get fire phone battery in UAE Abu Dhabi. It's urgent..
Asheesh Barna - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 36
今までの合計 12,634
