メインコンテンツにスキップ
Amazon Fire HDX 8.9" 4th Gen. Screen Replacement
必要な工具と部品
  1. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement, Screen: 手順 1、 3の画像 1 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement, Screen: 手順 1、 3の画像 2 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement, Screen: 手順 1、 3の画像 3
    • Ensure that the device is turned off.
    • Holding the device firmly, wedge a plastic opening tool between the speaker cover and the device. Then pry up to separate it from the device.
    • Then begin to firmly pry up the plastic cover with the plastic opening tool.
    • The backing is connected with adhesive so force may be necessary.
    • Be careful to not damage the plastic in any way.
    • Once you can fit your finger under the plastic cover, begin to slide your finger down the cover while simultaneously prying up.
  2. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 2、 2の画像 1 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 2、 2の画像 2
    • Once you reach the end of the plastic cover you should be able to completely remove it from the device.
  3. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 3、 2の画像 1 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 3、 2の画像 2
    • Use a T5 screwdriver to remove the four 3.5 mm T5 screws at the top of the device, where the black plastic trim was located.
  4. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 4、 3の画像 1 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 4、 3の画像 2 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 4、 3の画像 3
    • Release the two clear plastic clips at the top of the device near the speaker using the spudger.
    • Simply push down the clip with the tip of the spudger.
    • Push lightly to ensure that the clips aren't damaged.
  5. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 5、 3の画像 1 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 5、 3の画像 2 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 5、 3の画像 3
    • Use a plastic opening tool to wedge between the screen and the device, while simultaneously holding the clip open from step 4.
    • Pry the screen very gently to avoid cracking the glass
    • Start to remove the screen from where the black plastic trim was removed and work the tool around the sides of the device. You will here small pops from the clips on the sides being released.
    • The Amazon Fire can now be opened with the two flex cables at the base still connected
  6. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 6、 2の画像 1 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 6、 2の画像 2
    • Now we have to remove the two flex cables attached to both the screen assembly and body of the device.
    • The cable addressed in step 8 is highlighted in orange.
  7. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 7、 3の画像 1 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 7、 3の画像 2 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 7、 3の画像 3
    • First turn the device 90 degrees counterclockwise.
    • Wedge a spudger or plastic opening tool under the black flap of the larger connector and lift up.
    • Pull the belt out of the connector and lift it up.
  8. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 8、 3の画像 1 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 8、 3の画像 2 Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 8、 3の画像 3
    • Turn the device 180 degrees.
    • Repeat step 7 for the smaller flex cable connection.
  9. Amazon Fire HDX 8.9" 4th Gen. Screen Replacement: 手順 9、 1の画像 1
    • Your screen assembly has now been removed and can be replaced.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Sidney Stefani
メンバー登録日: 04/11/16
463 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 1-8, Maness Spring 2016 Cal Poly, Team 1-8, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S1G8
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 2,978
