はじめに
In this guide, we will show you how to replace the rear-facing camera. Before you start, make sure your device is powered off.
必要な工具と部品
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
この手順で使用する道具:Tweezers$4.99
Pop the camera out of the rear-facing camera casing by carefully pulling the orange cable with the tweezers.
終わりに
2 の人々がこのガイドを完成させました。
