メインコンテンツにスキップ
Amazon Fire HD 10 Screen Replacement
必要な工具と部品
  1. Amazon Fire HD 10 Screen Replacement, Screen: 手順 1、 3の画像 1 Amazon Fire HD 10 Screen Replacement, Screen: 手順 1、 3の画像 2 Amazon Fire HD 10 Screen Replacement, Screen: 手順 1、 3の画像 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: 手順 2、 1の画像 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: 手順 3、 2の画像 1 Amazon Fire HD 10 Screen Replacement: 手順 3、 2の画像 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: 手順 4、 1の画像 1
    • Remove the screen and digitizer from the case completely.
終わりに
26 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jaie Hillery
メンバー登録日: 10/07/14
1,718 ポイント
10のガイドは作成済み
チーム
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S16G6
3 メンバー
22のガイドは作成済み
16 件のコメント
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - 返信
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - 返信
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - 返信
What is needed to attach the screen back to the case?
Jimmy Lee - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 30
過去 30 日: 148
今までの合計 34,814
