メインコンテンツにスキップ
はじめに
You will need to use the screen replacement guide as a prerequisite.
パーツ
パーツは指定されていません。
  1. Avoid prying near bottom right hand side due to LCD Connector Use a plastic opening tool to pry the screen up in the right hand corner. Use a plastic opening tool to pry the screen up in the right hand corner.
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Do not completely remove the screen yet as there is a ZIF connector connected.
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Be mindful of the ZIF connector. Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Remove the screen and digitizer from the case completely.
    • Remove the screen and digitizer from the case completely.
  5. Remove the single T5 Torx screw at the base of the camera. Once removed, place the screw aside in a safe location.
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  6. Lift the camera from the case using the plastic opening tool. The camera is still connected to the motherboard via the ZIF connector.
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  7. Gently grab the camera and pull  to remove. The camera is now free from the motherboard.
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
Jaie Hillery
メンバー登録日: 2014年10月07日
1,676 ポイント
10のガイドは作成済み
チーム
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S16G6
3 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 709
