はじめに
You will need to use the screen replacement guide as a prerequisite.
必要な工具と部品
Lift the screen and digitizer from the case.
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
The right side with the power switch on top?
Sonny Shear - 返信
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - 返信
