はじめに
This guide will show you how to properly replace the outer shell of the Amazon Fire game controller. This procedure may be necessary when a part of the outer shell becomes damaged, and will remedy both functionality and cosmetic issues.
必要な工具と部品
Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
Use a JIS #0 screwdriver to remove the two 7 mm screws from the retaining bracket that secures the play, stop, and pause button wiring.
もう少しです!
終わりに
