メインコンテンツにスキップ
Amazon Echo Woofer Replacement
必要な工具と部品
  1. Amazon Echo Woofer Replacement, Power and Speaker Driver Board: 手順 1、 1の画像 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Woofer Replacement: 手順 2、 3の画像 1 Amazon Echo Woofer Replacement: 手順 2、 3の画像 2 Amazon Echo Woofer Replacement: 手順 2、 3の画像 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Woofer Replacement: 手順 3、 1の画像 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Woofer Replacement: 手順 4、 1の画像 1
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
    Könnt ihr Ersatzteil machen für Amazon Echo
    Okka Mehmed - 返信
    Wo kann ich Ersatzteile holen für Amazon Echo
    Okka Mehmed - 返信
  5. Amazon Echo Woofer Replacement: 手順 5、 2の画像 1 Amazon Echo Woofer Replacement: 手順 5、 2の画像 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
    Were do you get the board?
    nick poverman - 返信
  6. Amazon Echo Woofer Replacement: 手順 6、 3の画像 1 Amazon Echo Woofer Replacement: 手順 6、 3の画像 2 Amazon Echo Woofer Replacement: 手順 6、 3の画像 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
    I need to find a replacement board. Where can I find one?
    Matthew Webster - 返信
    Me to, i need this board to my alexa echo
    benjaminaflorentino - 返信
    So anyone found out where we can get these boards and other components ?
    Jimmy - 返信
  7. Amazon Echo Woofer Replacement, Tweeter Assembly: 手順 7、 2の画像 1 Amazon Echo Woofer Replacement, Tweeter Assembly: 手順 7、 2の画像 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Woofer Replacement: 手順 8、 1の画像 1
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Woofer Replacement: 手順 9、 3の画像 1 Amazon Echo Woofer Replacement: 手順 9、 3の画像 2 Amazon Echo Woofer Replacement: 手順 9、 3の画像 3
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
  10. Amazon Echo Woofer Replacement, Woofer: 手順 10、 1の画像 1
    • Lift the woofer out of the Echo.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Alexander Albert
メンバー登録日: 02/04/16
1,137 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G3
4 メンバー
12のガイドは作成済み
3 件のコメント
Where can you buy a replacement woofer?
adam mierzwa - 返信
My exact question.
Marty Koenig -
Could you post the dimension of the woofer unit? Its depth and diameter (and possibly screw holes location/diameter)? That would be very useful. Thank you.
No Body - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 27
今までの合計 7,648
