はじめに
This guide will show you how to replace the woofer, the speaker in the Amazon Echo responsible for the low-frequency bass. This guide should be helpful if your Echo is lacking bass or sounds otherwise distorted.
必要な工具と部品
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
ある他の人がこのガイドを完成しました。
3件のガイドコメント
Where can you buy a replacement woofer?
adam mierzwa - 返信 共有
My exact question.
Marty Koenig - 返信 共有
