Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
Peel off the rubber footing from the bottom of the Echo.
Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Tugging on the wires may damage the device. Pull from the plastic connectors instead.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
Using a spudger or your fingers, pull back the plastic clips near the edge of the tweeter.
Remove the tweeter from its plastic housing.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
