この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide demonstrates how to replace the tweeter in the Amazon Echo. This speaker delivers the higher pitched sounds when the Echo talks to you or plays any audio. This guide should be helpful if the audio from your Echo sounds distorted.
必要な工具と部品
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
Using a spudger or your fingers, pull back the plastic clips near the edge of the tweeter.
Remove the tweeter from its plastic housing.
ある他の人がこのガイドを完成しました。
3 件のコメント
Anyone know where to get a replacement tweeter?
Can anyone provide me the spare tweeter of Amazon echo dot 3rd generation
