メインコンテンツにスキップ
はじめに
This guide demonstrates how to replace the tweeter assembly in the Amazon Echo. Removing the assembly is a prerequisite for replacing the tweeter or woofer.
パーツ
パーツは指定されていません。
  1. Amazon Echo Tweeter Assembly Replacement, Power and Speaker Driver Board: 手順 1、 1の画像 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Tweeter Assembly Replacement: 手順 2、 3の画像 1 Amazon Echo Tweeter Assembly Replacement: 手順 2、 3の画像 2 Amazon Echo Tweeter Assembly Replacement: 手順 2、 3の画像 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Tweeter Assembly Replacement: 手順 3、 1の画像 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Tweeter Assembly Replacement: 手順 4、 1の画像 1
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Tweeter Assembly Replacement: 手順 5、 2の画像 1 Amazon Echo Tweeter Assembly Replacement: 手順 5、 2の画像 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Tweeter Assembly Replacement: 手順 6、 3の画像 1 Amazon Echo Tweeter Assembly Replacement: 手順 6、 3の画像 2 Amazon Echo Tweeter Assembly Replacement: 手順 6、 3の画像 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: 手順 7、 2の画像 1 Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: 手順 7、 2の画像 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Tweeter Assembly Replacement: 手順 8、 1の画像 1
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Tweeter Assembly Replacement: 手順 9、 3の画像 1 Amazon Echo Tweeter Assembly Replacement: 手順 9、 3の画像 2 Amazon Echo Tweeter Assembly Replacement: 手順 9、 3の画像 3
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
終わりに
Alexander Albert
メンバー登録日: 2016年02月04日
1,130 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G3
4 メンバー
12のガイドは作成済み
3 件のコメント
I've gotten this far, but where do you get a replacement? No brand or model # on tweeter.
Kyle - 返信
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
kathy1557 - 返信
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
Ron Davis -
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 3,377
