はじめに
The volume buttons on your Echo Show help you control how loud Alexa and your music plays, so if any of those buttons are not working properly, try restarting your Echo Show first. If it still doesn't work, then it's possible your volume button board is damaged. Follow these instructions to see how you can replace it.
必要な工具と部品
Use a prying tool to remove the rubber foot at the bottom.
Use an opening pick to remove the screw cover.
Gently tilt the shell towards the top of the device and disconnect the ribbon cable from the board on the case.
Use an opening tool to flip up the black ZIF locking flap that secure the four ribbon cables.
Remove the three 6 mm screws that secure the board using a TR4 Torx screwdriver.
