メインコンテンツにスキップ
Amazon Echo Show 8 3rd Gen Display Assembly Replacement
必要な工具と部品
  1. Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Power Board: 手順 1、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Power Board: 手順 1、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Power Board: 手順 1、 3の画像 3
    • Use a prying tool to remove the rubber foot at the bottom.
    • It is secured with adhesive and will lift off with some gentle prying.
    • Use an opening pick to remove the screw cover.
  2. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 2、 2の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 2、 2の画像 2
    • Use a Torx TR8 screwdriver to remove the two 2 cm screws.
  3. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 3、 2の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 3、 2の画像 2
    • Insert a jimmy in the gap between the display and chassis.
    • Pry around the perimeter until the back case releases.
    • Be careful as to not damage the ribbon cable on the top left area of the screen.
    • Remove the back case.
  4. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 4、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 4、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 4、 3の画像 3
    • Use a Torx TR6 screwdriver to remove the two 5 mm screws that secure the power board.
    • Carefully lift the board without straining the ribbon cable.
    • Using an opening tool, carefully flip up the black ZIF locking flap that secures the ribbon cable.
    • Disconnect the ribbon cable.
  5. Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Speakers: 手順 5、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Speakers: 手順 5、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Speakers: 手順 5、 3の画像 3
    • Gently tilt the shell towards the top of the device and disconnect the ribbon cable from the board on the case.
    • Don't tilt the cable too much as you can damage the ribbon or the connector.
  6. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 6、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 6、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 6、 3の画像 3
    • Use a TR6 screwdriver to remove the six 7mm screws located around the speaker assembly.
    • Gently tilt the speaker assembly towards the ribbon cable.
    • The ribbon cable is fragile and can be damaged if moved any other way.
    • Flip open the black tab on the connector towards the cable and gently pull.
    • Don't use too much force pulling up on the tab, as it can break and the cable will no longer be properly connected.
  7. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 7、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 7、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 7、 3の画像 3
    • Use a TR6 Torx screwdriver to remove the eight 9 mm screws holding the metal bracket.
    • Gently lift off the metal bracket.
  8. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 8、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 8、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 8、 3の画像 3
    • Remove the 2 rubber stoppers.
    • Remove all 14 screws with a Phillips #1 screwdriver.
  9. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 9、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 9、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 9、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the four 1.3 cm screws holding down each driver.
    • Gently pull the plastic plate towards the antenna cable.
    • There is a small antenna cable that is easy to rip off the solder joint, so lift carefully.
    • There are 8 screws on the long side of the housing, but there is no driver behind it, so you don't need to remove them.
  10. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 10、 2の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 10、 2の画像 2
    • Pry the speakers from the housing with a spudger.
    • The speakers are connected to a spring-loaded pin connector which is attached to the black plastic using industrial hot glue, so while you can heat the glue to remove it, the plastic may melt and/or deform, so we wouldn't recommend it.
  11. Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Motherboard: 手順 11、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Motherboard: 手順 11、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Motherboard: 手順 11、 3の画像 3
    • Use an opening tool to flip up the black ZIF locking flap that secure the four ribbon cables.
  12. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 12、 2の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 12、 2の画像 2
    • Use angled tweezers to disconnect all the ribbon cables from their motherboard sockets.
    • The ribbon cables are fragile; pull with care.
  13. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 13、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 13、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 13、 3の画像 3
    • Remove all 10 5 mm screws on the motherboard using a TR6 Torx screwdriver.
  14. Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Volume Buttons: 手順 14、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Volume Buttons: 手順 14、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Volume Buttons: 手順 14、 3の画像 3
    • Remove the three 6 mm screws that secure the board using a TR4 Torx screwdriver.
  15. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 15、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 15、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 15、 3の画像 3
    • Use an opening tool to flip open the black ZIF locking flap that secures the ribbon cable.
    • Be gentle with the ribbon cable.
    • Use tweezers to remove both buttons from the case.
  16. Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Display Assembly: 手順 16、 2の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement, Display Assembly: 手順 16、 2の画像 2
    • Remove the three 6 mm screws with a TR4 Torx screwdriver; remove the top buttons.
    • Remove the two 7 mm screws with a TR6 Torx screwdriver; remove the camera.
  17. Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 17、 3の画像 1 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 17、 3の画像 2 Amazon Echo Show 8 3rd Gen Display Assembly Replacement: 手順 17、 3の画像 3
    • Remove the plastic cover.
    • Remove the button and camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Venkat Reddy Kammala
メンバー登録日: 08/28/24
589 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team 6-5, Kilpatrick Fall 2024 University of North Texas, Team 6-5, Kilpatrick Fall 2024人のメンバー
UNT-KILPATRICK-F24S6G5
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 46
過去 30 日: 174
今までの合計 1,566
