はじめに
This guide serves to illustrate how to replace the speakers in this device. It is demonstrated in a few, moderate level steps that can be replicated using a couple different screwdrivers.
必要な工具と部品
Unscrew the white case using the TR1 screwdriver bit to remove the 4mm screws.
Pull on the top until the case becomes fully dislodged.
Firmly grasp the white trim of the front piece with one hand while the other pulls back on the black back portion of the device.
ある他の人がこのガイドを完成しました。
2 件のコメント
Where do I get replacement speakers at?
John Henry - 返信
These instructions are missing one important step, at least on my version of the Echo Show 10 2nd gen. There are 8 Tr8 screws holding the big black backside with the speakers + sound card in place 4 at the top, 2 on each side and 2 at the bottom. Note the 2 screws at the bottom are behind the white cover removed in step 1.
These 8 screws need to be removed before separating the back from the front in Step 5 of this guide.
Note the white cover is not only attached with 6 tr1 screws there also is some double-sided tape holding it in place at the edge near the power-connector you can see the tape remains at the first Picture of step 3 of the Sound Card replacement guide.
