メインコンテンツにスキップ
Amazon Echo Show 2nd Gen Sound Card Replacement
必要な工具と部品
  1. Amazon Echo Show 2nd Gen Sound Card Replacement, Sound foam: 手順 1、 3の画像 1 Amazon Echo Show 2nd Gen Sound Card Replacement, Sound foam: 手順 1、 3の画像 2 Amazon Echo Show 2nd Gen Sound Card Replacement, Sound foam: 手順 1、 3の画像 3
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 2、 3の画像 1 Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 2、 3の画像 2 Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 2、 3の画像 3
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
  3. Amazon Echo Show 2nd Gen Sound Card Replacement, Sound Card: 手順 3、 3の画像 1 Amazon Echo Show 2nd Gen Sound Card Replacement, Sound Card: 手順 3、 3の画像 2 Amazon Echo Show 2nd Gen Sound Card Replacement, Sound Card: 手順 3、 3の画像 3
    • Unscrew the white case using the TR1 screwdriver bit to remove the 4mm screws.
    • Pull on the top until the case becomes fully dislodged.
  4. Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 4、 2の画像 1 Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 4、 2の画像 2
    • Pull out the two white plugs by firmly grasping them and pulling in a downward motion until they become disconnected.
  5. Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 5、 1の画像 1
    • Unscrew the 4mm, red-marked screws with the TR6 screwdriver bit.
    • Detach the ribbon from the circuit board by grasping from the top of the ribbon and pulling away from the board.
  6. Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 6、 3の画像 1 Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 6、 3の画像 2 Amazon Echo Show 2nd Gen Sound Card Replacement: 手順 6、 3の画像 3
    • Unscrew the red-marked, 4mm screws with the J1 screwdriver bit.
    • Carefully slide the sound card up and out of the black casing.
終わりに
作成者
4人の作成者と共同で作成されました。
Schyler Sapinski
メンバー登録日: 01/13/20
332 ポイント
2のガイドは作成済み
1件のガイドコメント
Hi where can I purchase the board
Shem David - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 35
今までの合計 610
