メインコンテンツにスキップ
Amazon Echo Motherboard Replacement
必要な工具と部品
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: 手順 1、 1の画像 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: 手順 2、 3の画像 1 Amazon Echo Motherboard Replacement: 手順 2、 3の画像 2 Amazon Echo Motherboard Replacement: 手順 2、 3の画像 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: 手順 3、 1の画像 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: 手順 4、 1の画像 1
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
    Könnt ihr Ersatzteil machen für Amazon Echo
    Okka Mehmed - 返信
    Wo kann ich Ersatzteile holen für Amazon Echo
    Okka Mehmed - 返信
  5. Amazon Echo Motherboard Replacement: 手順 5、 2の画像 1 Amazon Echo Motherboard Replacement: 手順 5、 2の画像 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
    Were do you get the board?
    nick poverman - 返信
  6. Amazon Echo Motherboard Replacement: 手順 6、 3の画像 1 Amazon Echo Motherboard Replacement: 手順 6、 3の画像 2 Amazon Echo Motherboard Replacement: 手順 6、 3の画像 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
    I need to find a replacement board. Where can I find one?
    Matthew Webster - 返信
    Me to, i need this board to my alexa echo
    benjaminaflorentino - 返信
    So anyone found out where we can get these boards and other components ?
    Jimmy - 返信
  7. Amazon Echo Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 Amazon Echo Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
    These instructions are not going to help me because I am trying to repair an Alexa Echo Show.
    Tami Schaumburg - 返信
  8. Amazon Echo Motherboard Replacement: 手順 8、 1の画像 1
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: 手順 9、 2の画像 1 Amazon Echo Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: 手順 10、 3の画像 1 Amazon Echo Motherboard Replacement: 手順 10、 3の画像 2 Amazon Echo Motherboard Replacement: 手順 10、 3の画像 3
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: 手順 11、 1の画像 1
    • Lift the motherboard up from the Echo.
    Without a source for replacement motherboards this guide is useless.
    thomassmailus - 返信
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alexander Albert
メンバー登録日: 02/04/16
1,145 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G3
4 メンバー
12のガイドは作成済み
11 件のコメント
Where can you get the mmotherboard
Glen Seay - 返信
same question. where do i get replacement motherboard?
akn978s - 返信
This is how to remove the motherboard not how to replace it....geez
adairt - 返信
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - 返信
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - 返信
Any luck with finding a replacement motherboard ?
Rebel Face - 返信
Where can i get the amazon echo plus motherboard ? any resellers
Shyam Sunder - 返信
Where can i get the amazon echo plus 1st generation motherboard
Shyam Sunder - 返信
i am in need of the motherboard where do i get it please ?
Shyam Sunder - 返信
Parts can be found on eBay guys.
Andrew K - 返信
No they cannot , I see zero listings for echo motherboards. If the part was produced here would be listings. Amazon produced just enough and shut production down. Manufacturer of ewaste is best I can classify amazon as given the electronic device just does after 5-7 Years of at most using electricity.
thomassmailus -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 54
今までの合計 14,606
