はじめに
This guide demonstrates how to replace the motherboard in the Amazon Echo. The motherboard is responsible for all major functions of the Echo. It contains the Digital Media Processor, 256 MB LPDDR1 RAM, 4 GB flash memory, and the Wi-Fi and Bluetooth module.
必要な工具と部品
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Könnt ihr Ersatzteil machen für Amazon Echo
Wo kann ich Ersatzteile holen für Amazon Echo
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
I need to find a replacement board. Where can I find one?
Me to, i need this board to my alexa echo
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
These instructions are not going to help me because I am trying to repair an Alexa Echo Show.
Lift the motherboard up from the Echo.
4 の人々がこのガイドを完成させました。
11 件のコメント
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - 返信
Any luck with finding a replacement motherboard ?
Rebel Face - 返信
Where can i get the amazon echo plus motherboard ? any resellers
Where can i get the amazon echo plus 1st generation motherboard
i am in need of the motherboard where do i get it please ?
No they cannot , I see zero listings for echo motherboards. If the part was produced here would be listings. Amazon produced just enough and shut production down. Manufacturer of ewaste is best I can classify amazon as given the electronic device just does after 5-7 Years of at most using electricity.
