メインコンテンツにスキップ
Amazon Echo Motherboard Replacement
必要な工具と部品
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: 手順 1、 1の画像 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: 手順 2、 3の画像 1 Amazon Echo Motherboard Replacement: 手順 2、 3の画像 2 Amazon Echo Motherboard Replacement: 手順 2、 3の画像 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: 手順 3、 1の画像 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Motherboard Replacement: 手順 5、 2の画像 1 Amazon Echo Motherboard Replacement: 手順 5、 2の画像 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Motherboard Replacement: 手順 6、 3の画像 1 Amazon Echo Motherboard Replacement: 手順 6、 3の画像 2 Amazon Echo Motherboard Replacement: 手順 6、 3の画像 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 Amazon Echo Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Motherboard Replacement: 手順 8、 1の画像 1
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: 手順 9、 2の画像 1 Amazon Echo Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: 手順 10、 3の画像 1 Amazon Echo Motherboard Replacement: 手順 10、 3の画像 2 Amazon Echo Motherboard Replacement: 手順 10、 3の画像 3
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: 手順 11、 1の画像 1
    • Lift the motherboard up from the Echo.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alexander Albert
メンバー登録日: 02/04/16
1,169 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G3
4 メンバー
12のガイドは作成済み
11件のガイドコメント
Where can you get the mmotherboard
Glen Seay - 返信
same question. where do i get replacement motherboard?
akn978s - 返信
This is how to remove the motherboard not how to replace it....geez
adairt - 返信
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - 返信
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 83
今までの合計 15,713
