はじめに
This guide demonstrates how to remove the LED/Microphone board. This board contains the LED indication ring at the top of the Echo, as well as the seven microphone array. This guide should assist you if the LED ring is malfunctioning or if the Echo has issues hearing you.
必要な工具と部品
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
6 の人々がこのガイドを完成させました。
2 件のコメント
Where can i buy this LED/Microphone board for replacement?
