はじめに
If your speaker needs to be replaced, you can access it with this guide. If needed, you can also replace the case, ribbon cable, CPU PCB, and switch PCB since this device is relatively small and the parts are relatively close together. For this replacement, you'll need a spudger, safe pry tool, T6 Torx screwdriver head, and a T8 Torx screwdriver head.
必要な工具と部品
Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
To access the speaker, take a plastic spudger and slowly lift the ribbon off of the housing.
Remove the four T8 1cm Torx screws around the edges of the metal housing.
Lift the top case off of the housing to reveal the speaker.
ある他の人がこのガイドを完成しました。
