メインコンテンツにスキップ
Amazon Echo Dot 3rd Generation Motherboard Replacement
必要な工具と部品
  1. Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 手順 1、 3の画像 1 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 手順 1、 3の画像 2 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 手順 1、 3の画像 3
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Motherboard Replacement: 手順 2、 2の画像 1 Amazon Echo Dot 3rd Generation Motherboard Replacement: 手順 2、 2の画像 2
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Motherboard Replacement: 手順 3、 1の画像 1
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Motherboard Replacement: 手順 4、 2の画像 1 Amazon Echo Dot 3rd Generation Motherboard Replacement: 手順 4、 2の画像 2
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 手順 5、 3の画像 1 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 手順 5、 3の画像 2 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 手順 5、 3の画像 3
    • Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
    • Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
  6. Amazon Echo Dot 3rd Generation Motherboard Replacement: 手順 6、 3の画像 1 Amazon Echo Dot 3rd Generation Motherboard Replacement: 手順 6、 3の画像 2 Amazon Echo Dot 3rd Generation Motherboard Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Remove the connecting head linking the motherboard to the device using a pair of tweezers.
    • Remove the old motherboard and replace it with the new one.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jacquelyn Jones
メンバー登録日: 09/15/22
308 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 3-2, Lane Fall 2022 University of Memphis, Team 3-2, Lane Fall 2022人のメンバー
UM-LANE-F22S3G2
4 メンバー
5のガイドは作成済み
3件のガイドコメント
Where do we get the parts you bi chh
Fcukermother - 返信
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
raymondjram -
Can you get or buy replament mother boards for the ehco 5 ?
Shawn Haywood - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 148
今までの合計 2,899
