メインコンテンツにスキップ
Amazon Echo Dot 3rd Gen Disassembly
必要な工具と部品
  1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 手順 1、 3の画像 1 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 手順 1、 3の画像 2 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 手順 1、 3の画像 3
    • When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
    • Avoid letting the Adhesive touch anything, lay the plate on the branded side
    • If the adhesive is to strong use a hair dryer to soften it
  2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 手順 2、 3の画像 1 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 手順 2、 3の画像 2 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 手順 2、 3の画像 3
    • Use a TORX T6H bit to remove the four screws on the bottom
    • When all the screws are taken out lift up and the covering should slide off
  3. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 手順 3、 3の画像 1 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 手順 3、 3の画像 2 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 手順 3、 3の画像 3
    • Remember to un latch the ribbon cable before pulling the circuit board up
  4. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 手順 4、 3の画像 1 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 手順 4、 3の画像 2 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 手順 4、 3の画像 3
    • To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
    • Pull up on the metal to release the top from the rest
  5. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 手順 5、 3の画像 1 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 手順 5、 3の画像 2 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 手順 5、 3の画像 3
    • Undo the four screws the remove the white defuser piece (I lost a screw)
  6. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: 手順 6、 2の画像 1 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: 手順 6、 2の画像 2
    • The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ben Nicholsonb
メンバー登録日: 07/09/21
349 ポイント
1ガイドが承認済み
3件のガイドコメント
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
eduardosanchessales - 返信
How can I convert Amazon Echo Dot power from AC to DC?
Gift Sikufele - 返信
ciao, per caso sai indicarmi la parte specializzata per la rete wi-fi o segnali, ho un eco dot uguale e non viene rilevato in nessun modo per questo volevo vedere se ci fosse qualche problema al ricevitore wifi
Matteo Sala - 返信
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 110
過去 30 日: 456
今までの合計 15,765
