メインコンテンツにスキップ
Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement
必要な工具と部品
  1. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: 手順 1、 3の画像 1 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: 手順 1、 3の画像 2 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: 手順 1、 3の画像 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
  2. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 2、 3の画像 1 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 2、 3の画像 2 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 2、 3の画像 3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 3、 3の画像 1 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 3、 3の画像 2 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 3、 3の画像 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 4、 1の画像 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 5、 3の画像 1 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 5、 3の画像 2 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 5、 3の画像 3
    • Remove the silver divider
    • Remove black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 6、 3の画像 1 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 6、 3の画像 2 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 6、 3の画像 3
    • Remove the ribbon cable from the slot on the LED/speaker board
  7. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: 手順 7、 1の画像 1
    • Remove the LED/speaker board
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cassidy O'Connor
メンバー登録日: 10/09/17
465 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S1-G3, Leahy Fall 2017 USF Tampa, Team S1-G3, Leahy Fall 2017人のメンバー
USFT-LEAHY-F17S1G3
3 メンバー
12のガイドは作成済み
1件のガイドコメント
I can’t seem to find the board anywhere. Where would you buy one?
George hanes - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 40
今までの合計 5,569
