メインコンテンツにスキップ
Aluratek ADMPF310F Motherboard Replacement
必要な工具と部品
  1. Aluratek ADMPF310F Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Aluratek ADMPF310F Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Aluratek ADMPF310F Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Motherboard Replacement: 手順 2、 1の画像 1
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Motherboard Replacement: 手順 3、 2の画像 1 Aluratek ADMPF310F Motherboard Replacement: 手順 3、 2の画像 2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Motherboard Replacement: 手順 4、 1の画像 1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Motherboard Replacement: 手順 5、 1の画像 1
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Motherboard Replacement: 手順 6、 2の画像 1 Aluratek ADMPF310F Motherboard Replacement: 手順 6、 2の画像 2
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Motherboard Replacement: 手順 7、 3の画像 1 Aluratek ADMPF310F Motherboard Replacement: 手順 7、 3の画像 2 Aluratek ADMPF310F Motherboard Replacement: 手順 7、 3の画像 3
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Motherboard Replacement: 手順 8、 1の画像 1
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
終わりに
作成者
2人の作成者と共同で作成されました。
Pascal Alexis
メンバー登録日: 11/05/15
427 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S5G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 14
今までの合計 562
