メインコンテンツにスキップ
Altec Lansing VersA Smart Speaker Head Replacement
必要な工具と部品
  1. Altec Lansing VersA Smart Speaker Head Replacement, External Panels: 手順 1、 1の画像 1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Speaker Head Replacement: 手順 2、 2の画像 1 Altec Lansing VersA Smart Speaker Head Replacement: 手順 2、 2の画像 2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Speaker Head Replacement: 手順 3、 2の画像 1 Altec Lansing VersA Smart Speaker Head Replacement: 手順 3、 2の画像 2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Speaker Head Replacement: 手順 4、 1の画像 1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: 手順 5、 3の画像 1 Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: 手順 5、 3の画像 2 Altec Lansing VersA Smart Speaker Head Replacement, Speaker Head: 手順 5、 3の画像 3
    • Detach the two wire connections from the motherboard.
    • Remove the speaker bed from the internal cavity of the device.
  6. Altec Lansing VersA Smart Speaker Head Replacement: 手順 6、 2の画像 1 Altec Lansing VersA Smart Speaker Head Replacement: 手順 6、 2の画像 2
    • Orient speaker bed so the speaker heads are facing up.
    • Remove the two 14mm screws using the Phillips #1 screwdriver.
  7. Altec Lansing VersA Smart Speaker Head Replacement: 手順 7、 2の画像 1 Altec Lansing VersA Smart Speaker Head Replacement: 手順 7、 2の画像 2
    • Separate the two plastic pieces of the speaker bed.
    • Flip the top plastic piece so the speaker heads are face down.
    • Speaker heads may fall out on their own.
    • Remove the two speaker heads.
終わりに
作成者
2人の作成者と共同で作成されました。
Rachael Hopp
メンバー登録日: 09/10/18
550 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S1-G3, Bedsole Fall 2018 University of Alabama, Team S1-G3, Bedsole Fall 2018人のメンバー
UA-BEDSOLE-F18S1G3
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 479
