メインコンテンツにスキップ
Altec Lansing VersA Smart Micro USB Port Replacement
必要な工具と部品
  1. Altec Lansing VersA Smart Micro USB Port Replacement, External Panels: 手順 1、 1の画像 1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Micro USB Port Replacement: 手順 2、 2の画像 1 Altec Lansing VersA Smart Micro USB Port Replacement: 手順 2、 2の画像 2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Micro USB Port Replacement: 手順 3、 2の画像 1 Altec Lansing VersA Smart Micro USB Port Replacement: 手順 3、 2の画像 2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Micro USB Port Replacement: 手順 4、 1の画像 1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Micro USB Port Replacement, Micro USB Port: 手順 5、 1の画像 1
    • Remove the plactic piece containing the Micro USB port from its designated slot, found below the speakers.
  6. Altec Lansing VersA Smart Micro USB Port Replacement: 手順 6、 1の画像 1
    • Detach both the wires connecting the Micro USB piece to the motherboard.
  7. Altec Lansing VersA Smart Micro USB Port Replacement: 手順 7、 1の画像 1
    • Remove the two 10mm screws using the Phillips #0 screwdriver.
  8. Altec Lansing VersA Smart Micro USB Port Replacement: 手順 8、 1の画像 1
    • Remove the small black plastic piece that was held in place by the two 10 mm screws and covers the Micro USB port.
  9. Altec Lansing VersA Smart Micro USB Port Replacement: 手順 9、 1の画像 1
    • Use the black plastic spudger to lightly push the Micro USB piece out of the external plastic piece.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Rachael Hopp
メンバー登録日: 09/10/18
550 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S1-G3, Bedsole Fall 2018 University of Alabama, Team S1-G3, Bedsole Fall 2018人のメンバー
UA-BEDSOLE-F18S1G3
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 1,101
