メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
If you need access to any of the internal components of your Altec Lansing VersA Smart speaker to replace components, start with this basic removal guide. This guide is a prerequisite to all other repair guides. In this guide, you will remove all external panels and coverings to expose the components within.
  1. Remove external rubber cover.
    • Remove external rubber cover.
  2. Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom. Use a lever motion, push the tool down, lifting the speaker face.
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Manta Driver Kit
    どんな修理にでも対応可能な112ビット
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side. Remove the seven 14mm screws using the Phillips #1 screwdriver.
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  5. Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
ゴール
Rachael Hopp
メンバー登録日: 2018年09月10日
517 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S1-G3, Bedsole Fall 2018 University of Alabama, Team S1-G3, Bedsole Fall 2018人のメンバー
UA-BEDSOLE-F18S1G3
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 91
