メインコンテンツにスキップ
Alpine Ski Wax Application
必要な工具と部品
  1. Alpine Ski Wax Application, Alpine Ski Wax Application: 手順 1、 1の画像 1
    • Attach heavy rubber bands around the brakes.
  2. Alpine Ski Wax Application: 手順 2、 1の画像 1
    • Spray base cleaner along the bottom of the ski.
  3. Alpine Ski Wax Application: 手順 3、 1の画像 1
    • Wipe the skis with a towel, removing dirt, excess wax, the base cleaner, and dust.
  4. Alpine Ski Wax Application: 手順 4、 1の画像 1
    • Spread wax across the base of the ski with an edge to edge motion. While doing this hold the iron perpendicular to the base and press the wax into the iron.
    • Be careful when handling the hot iron and the hot wax.
  5. Alpine Ski Wax Application: 手順 5、 1の画像 1
    • Melt the wax into the base using a tip to tail stroke with the iron.
    • Let the skis dry for at least 30 minutes once all the wax is melted.
  6. Alpine Ski Wax Application: 手順 6、 1の画像 1
    • Scrape the excess wax off with the plastic scraper. Continue this process until there is no visible wax on the ski base.
  7. Alpine Ski Wax Application: 手順 7、 1の画像 1
    • Scrape the excess wax off of the side of the ski.
  8. Alpine Ski Wax Application: 手順 8、 1の画像 1
    • Wipe the fine wax dust from the ski base.
ゴール
作成者
3人の作成者と共同で作成されました。
Evan Gornick
メンバー登録日: 09/26/17
101 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team S5-G4, Galliah Fall 2017 Michigan Tech, Team S5-G4, Galliah Fall 2017人のメンバー
MTU-GALLIAH-F17S5G4
2 メンバー
2のガイドは作成済み
8 件のコメント
Very nice post! That's a great website I have visited, thank you for your essentials words run 3
Martin Tolley - 返信
I read your article very detailed and easy to understand, I hope next time you will have more wonderful articles to share with the reader.
run 3
switch color - 返信
thansks for the post
Arun nagar - 返信
'''WYSIWYG Web Builder Crack''' has a unique and easy to use tools for both beginners and professional developers. Hence it is straightforward to use application.
Harry Oscar - 返信
I really enjoy the blog article. Much thanks again. Want more.
Wondershare Filmora Scrn Crack
DxO PhotoLab Crack
Harry Oscar - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 14
今までの合計 406
