メインコンテンツにスキップ
AlphaSmart Pro Motherboard Replacement
必要な工具と部品
  1. AlphaSmart Pro Motherboard Replacement, Separating Panels: 手順 1、 3の画像 1 AlphaSmart Pro Motherboard Replacement, Separating Panels: 手順 1、 3の画像 2 AlphaSmart Pro Motherboard Replacement, Separating Panels: 手順 1、 3の画像 3
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 手順 2、 3の画像 1 AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 手順 2、 3の画像 2 AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 手順 2、 3の画像 3
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • Remove front panel from the motherboard.
  3. AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 手順 3、 3の画像 1 AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 手順 3、 3の画像 2 AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 手順 3、 3の画像 3
    • Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard.
    • Gently lift the keyboard from the rear panel.
    • Notice that the keyboard is still connected to the motherboard by two ribbon cables.
  4. AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 手順 4、 3の画像 1 AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 手順 4、 3の画像 2 AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 手順 4、 3の画像 3
    • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
    • Pull the ribbon cable to remove it from the connector.
    • Repeat the exact steps above for the other ribbon cable.
    • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
  5. AlphaSmart Pro Motherboard Replacement: 手順 5、 1の画像 1
    • Remove keyboard from motherboard.
  6. AlphaSmart Pro Motherboard Replacement, Disconnecting Battery Prongs From Battery Compartment: 手順 6、 2の画像 1 AlphaSmart Pro Motherboard Replacement, Disconnecting Battery Prongs From Battery Compartment: 手順 6、 2の画像 2
    • Flip the AlphaSmart Pro over so that the rear panel is facing upward.
    • Using a spludger, carefully disconnect the battery prongs, located in the battery compartment.
  7. AlphaSmart Pro Motherboard Replacement, Separating Motherboard From Rear Panel.: 手順 7、 2の画像 1 AlphaSmart Pro Motherboard Replacement, Separating Motherboard From Rear Panel.: 手順 7、 2の画像 2
    • Using a Phillips #00 Screwdriver, remove the four 0.8 cm screws from the motherboard.
    • Carefully lift the motherboard away from the rear panel.
終わりに
作成者
3人の作成者と共同で作成されました。
Ashley Orr
メンバー登録日: 10/13/14
130 ポイント
2のガイドは作成済み
チーム
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G1
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 639
