メインコンテンツにスキップ
Allow Code42 (Crashplan) Access to Backup Personal Files
  1. Allow Code42 (Crashplan) Access to Backup Personal Files, Open Apple System Preferences: 手順 1、 1の画像 1
    • Click in the Apple logo in the top left hand corner of the screen, then select "System Preferences"
  2. Allow Code42 (Crashplan) Access to Backup Personal Files, Open Security and Privacy: 手順 2、 1の画像 1
    • Select "Security and Privacy"
  3. Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: 手順 3、 3の画像 1 Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: 手順 3、 3の画像 2 Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: 手順 3、 3の画像 3
    • If necessary, unlock the preference pane by clicking on the padlock in the lower left corner of the window, then enter your password. Once the padlock icon is in the open position, select the "Privacy" tab
    • Once in the Privacy tab, Scroll through the box on the left and select "Full Disk Access"
    • Check the box next to "Code42" in the "Full Disk Access" settings pane to allow Crashplan to backup your personal files.
    • The following message appears: "Code42" will not have full disk access until it is quit. Click Quit Now.
  4. Allow Code42 (Crashplan) Access to Backup Personal Files, Restart Your Mac: 手順 4、 1の画像 1
    • Though not strictly necessary, it is good practice to restart your computer to allow the changes you've made to take effect. The next time Code42 launches, it should have the permission it needs to access your home folder and backup your Desktop, Documents, Mail, Contacts, Photos, and more.
    • For more information on this change, see Code42's documentation at: https://support.code42.com/CrashPlan/6/T...
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Kevin Tully
メンバー登録日: 10/14/19
149 ポイント
1ガイドが承認済み
1件のガイドコメント
Great!! Thanks Kevin!
dahernandezs - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,602
