メインコンテンツにスキップ
Alienware m15 R6 Wireless card Replacement
必要な工具と部品
  1. Alienware m15 R6 Wireless card Replacement, Base Cover: 手順 1、 1の画像 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 Wireless card Replacement: 手順 2、 1の画像 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 Wireless card Replacement: 手順 3、 1の画像 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 Wireless card Replacement, Wireless card: 手順 4、 1の画像 1
    • Lift the system board Mylar to access the wireless card.
  5. Alienware m15 R6 Wireless card Replacement: 手順 5、 1の画像 1
    • Remove the screw (M2x4) that secures the wireless-card bracket to the system board and palm-rest and keyboard assembly.
    • Lift the wireless-card bracket off the wireless card.
    • Disconnect the antenna cables from the wireless card.
    • Slide and remove the wireless card from the wireless-card slot.
終わりに
作成者
1人の作成者と共同作成されました。
Andrzej
メンバー登録日: 02/17/23
1,702 ポイント
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 295
