メインコンテンツにスキップ
Alienware m15 R6 SSD slot two Replacement
必要な工具と部品
  1. Alienware m15 R6 SSD slot two Replacement, Base Cover: 手順 1、 1の画像 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 SSD slot two Replacement: 手順 2、 1の画像 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 SSD slot two Replacement: 手順 3、 1の画像 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 SSD slot two Replacement, Removing the solid-state drive in SSD slot two: 手順 4、 2の画像 1 Alienware m15 R6 SSD slot two Replacement, Removing the solid-state drive in SSD slot two: 手順 4、 2の画像 2
    • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and system board.
    • Lift the thermal shield off the solid-state drive.
    • Slide and lift the solid-state drive off the solid-state drive slot on the system board.
  5. Alienware m15 R6 SSD slot two Replacement, Procedure to move the screw mount in SSD slot two: 手順 5、 1の画像 1
    • Slide to remove the screw mount from the palm-rest and keyboard assembly.
    • Slide the screw mount into the other screw mount slot on the palm-rest and keyboard assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Andrzej
メンバー登録日: 02/17/23
1,702 ポイント
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 20
今までの合計 502
