メインコンテンツにスキップ
Alienware P18G M14X R1 Hard Drive Replacement
必要な工具と部品
  1. Alienware P18G M14X R1 Hard Drive Replacement, Back Cover: 手順 1、 1の画像 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Hard Drive Replacement: 手順 2、 1の画像 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Hard Drive Replacement: 手順 3、 1の画像 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Hard Drive Replacement, Battery: 手順 4、 1の画像 1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Hard Drive Replacement: 手順 5、 2の画像 1 Alienware P18G M14X R1 Hard Drive Replacement: 手順 5、 2の画像 2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Hard Drive Replacement: 手順 6、 1の画像 1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Hard Drive Replacement, Optical Drive: 手順 7、 1の画像 1
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Hard Drive Replacement: 手順 8、 1の画像 1
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Hard Drive Replacement: 手順 9、 1の画像 1
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
  10. Alienware P18G M14X R1 Hard Drive Replacement, Hard Drive: 手順 10、 1の画像 1
    • Loosen the three 6.35 mm screws using the PH1 screw driver, to release the hard drive.
    • The screws will not be able to be removed from the hard drive. They can only be loosened or tightened.
  11. Alienware P18G M14X R1 Hard Drive Replacement: 手順 11、 1の画像 1
    • Pull the tab on the hard drive slowly and carefuly because there will be a cable attached to it.
  12. Alienware P18G M14X R1 Hard Drive Replacement: 手順 12、 1の画像 1
    • Pull the clip away from the hard drive to remove it.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Andonaq Grozdani
メンバー登録日: 03/01/18
892 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 UMass Dartmouth, Team S2-G2, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G2
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 2,934
