メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will help with the compartment door replacement for the Alienware M17x P01E.
パーツ
パーツは指定されていません。
  1. Please power off the computer and deplete the battery before attempting the following step.
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Press down on the battery latch and slide it to the left. Lift the battery out once it pops out.
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Loosen the two silver Phillips #1 screws.
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Use your hand to gently lift and remove the compartment door. Use your hand to gently lift and remove the compartment door.
    • Use your hand to gently lift and remove the compartment door.
終わりに
Kevin Palacios
メンバー登録日: 2018年09月17日
169 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team S2-G2, Bruce Fall 2018 CSU Fullerton, Team S2-G2, Bruce Fall 2018人のメンバー
CSUF-BRUCE-F18S2G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 148
