メインコンテンツにスキップ
Alienware M17x Motherboard Replacement
必要な工具と部品
  1. Alienware M17x Motherboard Replacement, Battery: 手順 1、 2の画像 1 Alienware M17x Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Motherboard Replacement: 手順 4、 2の画像 1 Alienware M17x Motherboard Replacement: 手順 4、 2の画像 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
    • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
    • Twelve 5.5 mm Phillips #0 main frame screws.
    • Six 3.5 mm Phillips #0 fan screws.
    • Four 3.5 mm Phillips #0 internal compartment screws.
    • Eight 3.5 mm Phillips #0 Hard Drive screws.
    • Four 3.5 mm Phillips #0 CD Drive screws.
    • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
  6. Alienware M17x Motherboard Replacement: 手順 6、 3の画像 1 Alienware M17x Motherboard Replacement: 手順 6、 3の画像 2 Alienware M17x Motherboard Replacement: 手順 6、 3の画像 3
    • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
    • Use a plastic opening tool to pry the keyboard from the base of the computer.
  7. Alienware M17x Motherboard Replacement: 手順 7、 1の画像 1
    • Remove five 3.5 mm Phillips #0 screws from the motherboard.
    • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
    • Lift the motherboard at an angle and remove it from the computer base.
終わりに
作成者
1人の作成者と共同作成されました。
Mosier Locke
メンバー登録日: 09/27/18
729 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 1,780
