Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
Pull the assembly grip away to remove it.
Remove the two 5 mm screws using a Phillips #1 screwdriver.
Push in the assembly towards the spring.
Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
