メインコンテンツにスキップ
はじめに
Upgrade your RAM for an instant increase in speed.
The M15x uses DDR3 1333MHz memory.
  1. First, take off the battery by moving the latch to the left and pulling it up.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Unscrew the two screws indicated
    • Unscrew the two screws indicated
  4. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
終わりに
6 の人々がこのガイドを完成させました。
Gabe
メンバー登録日: 2010年04月09日
8,131 ポイント
3のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
290 メンバー
827のガイドは作成済み
コメント1件
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 24,003
