メインコンテンツにスキップ
Alienware M15x Processor Fan and Heat Sink Assembly Replacement
必要な工具と部品
  1. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Turn the Computer: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • Turn the computer over.
  2. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Sliding the Battery: 手順 2、 1の画像 1
    • Slide the battery latch to the unlock position as shown.
  3. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Removing the Battery Pack: 手順 3、 1の画像 1
    • After the Battery Pack pops up, remove the Battery Pack.
  4. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Aligning the Battery Pack Tabs: 手順 4、 1の画像 1
    • Align the battery pack tabs with the slots in the battery bay.
  5. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Pushing the Battery Pack: 手順 5、 1の画像 1
    • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
  6. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Loosen the Screws: 手順 6、 1の画像 1
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Loosen the two captive screws that secure the memory-module door to the computer base.
  7. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Lifting the Memory Module Door: 手順 7、 2の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Lifting the Memory Module Door: 手順 7、 2の画像 2
    • Slide the memory-module door to release the tabs and lift the memory-module door out of the computer base.
  8. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Popping up the Memory Module: 手順 8、 2の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Popping up the Memory Module: 手順 8、 2の画像 2
    • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
    • CAUTION: To prevent damage to the memory module connector(s), do not use tools to spread the memory module spring-locks.
    • Use your fingertips to carefully spread apart the spring-locks on the memory-module connector until the memory module pops up.
  9. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Remove the Memory Module: 手順 9、 1の画像 1
    • Remove the memory module.
  10. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Align the Notch: 手順 10、 3の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Align the Notch: 手順 10、 3の画像 2 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Align the Notch: 手順 10、 3の画像 3
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  11. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Insert the Module: 手順 11、 2の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Insert the Module: 手順 11、 2の画像 2
    • Insert the module into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
  12. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Align and Insert the Memory Module Tabs: 手順 12、 2の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Align and Insert the Memory Module Tabs: 手順 12、 2の画像 2
    • CAUTION: If the memory-module door is difficult to close, remove the memory module and reinstall it. Forcing the memory-module door to close may damage your computer.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    • Align and insert the memory-module door tabs into the slots on the computer base.
  13. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Replacing and Tightening the Screws: 手順 13、 1の画像 1
    • Replace and tighten the two captive screws that secure the memory-module door to the computer base.
  14. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Loosen the Screws: 手順 14、 1の画像 1
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • Loosen the four captive screws that secure the hard-drive assembly.
  15. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Lifting the Hard-Drive Assembly: 手順 15、 1の画像 1
    • Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
  16. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Remove the Screws: 手順 16、 1の画像 1
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  17. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Lifting the Hard Drive: 手順 17、 2の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Lifting the Hard Drive: 手順 17、 2の画像 2
    • Lift the hard drive out of the hard-drive bracket.
  18. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Disconnect the Interposer: 手順 18、 2の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Disconnect the Interposer: 手順 18、 2の画像 2
    • Disconnect the interposer from the hard drive.
  19. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Connecting the Interposer: 手順 19、 2の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Connecting the Interposer: 手順 19、 2の画像 2
    • Connect the interposer to the NEW hard drive.
  20. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Placing the Hard-Drive in the Bracket: 手順 20、 2の画像 1 Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Placing the Hard-Drive in the Bracket: 手順 20、 2の画像 2
    • Place the hard drive in the hard-drive bracket.
  21. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Replace the Four Screws: 手順 21、 1の画像 1
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  22. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Placing the Hard-Drive Assembly: 手順 22、 1の画像 1
    • Place the hard-drive assembly in the hard-drive bay.
  23. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Aligning and Tightening the Screws: 手順 23、 1の画像 1
    • Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
  24. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Disconnecting the Fan and Heat Sink Assembly: 手順 24、 1の画像 1
    • Disconnect the processor fan and heat sink assembly cable from the system board connector.
  25. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Loosen the Screws: 手順 25、 1の画像 1
    • In sequential order (indicated on the processor fan and heat sink assembly), loosen the four captive screws that secure the processor fan and heat sink assembly to the system board.
  26. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Lifting the Processor Fan and Heat-Sink Assembly: 手順 26、 1の画像 1
    • Lift the processor fan and heat sink assembly off the system board.
    • Peel the backing off the thermal cooling pads attached to the NEW processor fan and heat sink assembly.
    • NOTE: If the processor fan and heat sink assembly is replaced, the thermal cooling pads will be attached to the new processor fan and heat sink assembly. Do not reuse the old thermal cooling pads.
  27. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Align the Four Captive Screws: 手順 28、 1の画像 1
    • Align the four captive screws on the processor heat sink with the screw holes on the system board and tighten the screws in sequential order (indicated on the processor fan and heat sink assembly).
  28. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Tighten the Screw: 手順 29、 1の画像 1
    • Tighten the screw that secures the processor fan and heat sink assembly to the computer base.
  29. Alienware M15x Processor Fan and Heat Sink Assembly Replacement, Connect the Processor Fan and Heat Sink Assembly: 手順 30、 1の画像 1
    • Connect the processor fan and heat sink assembly cable to the system board connector.
終わりに
作成者
2人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
79,131 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,986のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 21
今までの合計 1,101
