メインコンテンツにスキップ
Alienware M15x Hard-Drive Replacement
必要な工具と部品
  1. Alienware M15x Hard-Drive Replacement, Turn the Computer: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • Turn the computer over.
  2. Alienware M15x Hard-Drive Replacement, Sliding the Battery: 手順 2、 1の画像 1
    • Slide the battery latch to the unlock position as shown.
  3. Alienware M15x Hard-Drive Replacement, Removing the Battery Pack: 手順 3、 1の画像 1
    • After the Battery Pack pops up, remove the Battery Pack.
  4. Alienware M15x Hard-Drive Replacement, Aligning the Battery Pack Tabs: 手順 4、 1の画像 1
    • Align the battery pack tabs with the slots in the battery bay.
  5. Alienware M15x Hard-Drive Replacement, Pushing the Battery Pack: 手順 5、 1の画像 1
    • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
  6. Alienware M15x Hard-Drive Replacement, Loosen the Screws: 手順 6、 1の画像 1
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • Loosen the four captive screws that secure the hard-drive assembly.
  7. Alienware M15x Hard-Drive Replacement, Lifting the Hard-Drive Assembly: 手順 7、 1の画像 1
    • Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
  8. Alienware M15x Hard-Drive Replacement, Remove the Screws: 手順 8、 1の画像 1
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  9. Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: 手順 9、 2の画像 1 Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: 手順 9、 2の画像 2
    • Lift the hard drive out of the hard-drive bracket.
  10. Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: 手順 10、 2の画像 1 Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: 手順 10、 2の画像 2
    • Disconnect the interposer from the hard drive.
  11. Alienware M15x Hard-Drive Replacement, Connecting the Interposer: 手順 11、 2の画像 1 Alienware M15x Hard-Drive Replacement, Connecting the Interposer: 手順 11、 2の画像 2
    • Connect the interposer to the NEW hard drive.
  12. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: 手順 12、 2の画像 1 Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: 手順 12、 2の画像 2
    • Place the hard drive in the hard-drive bracket.
  13. Alienware M15x Hard-Drive Replacement, Replace the Four Screws: 手順 13、 1の画像 1
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  14. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive Assembly: 手順 14、 1の画像 1
    • Place the hard-drive assembly in the hard-drive bay.
  15. Alienware M15x Hard-Drive Replacement, Aligning and Tightening the Screws: 手順 15、 1の画像 1
    • Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
終わりに
作成者
2人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
79,121 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,986のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 495
