メインコンテンツにスキップ
はじめに
Upgrade your hard drive for more storage space.
  1. First, take off the battery by moving the latch to the left and pulling it up.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Unscrew the four screws indicated Pull on the tab that says "Pull" and remove the Hard Drive
    • Unscrew the four screws indicated
    • Pull on the tab that says "Pull" and remove the Hard Drive
  4. With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with. With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
    • With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
終わりに
7 の人々がこのガイドを完成させました。
Gabe
メンバー登録日: 2010年04月09日
7,942 ポイント
3のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
300 メンバー
1,016のガイドは作成済み
コメント1件
Thanks, great guide. Was a bit confused between steps three and four but I simply had to remove the metal casing around the hard drive.
Hasan - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 36
今までの合計 32,362
