メインコンテンツにスキップ
はじめに
This guide will demonstrate how to install and mount a solid-state drive in an Alienware M15 - P97F. Solid-state drives are an emerging storage device used in many PC and laptops instead of hard drives.
Prior to beginning the replacement, be sure to shut down your device, and unplug your laptop from the external power supply.
After installation, this guide will show how to mount the new solid-state drive to the primary drive which will allow users to access the new drive from a folder in the primary drive.
  1. Shut down your computer by holding the power button for five seconds. Disconnect the computer from all attachments and power sources. Disconnect the computer from all attachments and power sources.
    • Shut down your computer by holding the power button for five seconds.
    • Disconnect the computer from all attachments and power sources.
  2. Use a Phillips #1 screwdriver to remove the six 2.4 mm screws from the bottom of the computer. Also, remove the two screws located near the base of the power cord. Loosen the three captive screws located closest to the touchpad.
    • Use a Phillips #1 screwdriver to remove the six 2.4 mm screws from the bottom of the computer.
    • Also, remove the two screws located near the base of the power cord.
    • Loosen the three captive screws located closest to the touchpad.
    • Remove the back case.
  3. Whenever removing or installing parts. The battery should be disconnected. Disconnect the battery cable from the system board.
    • Whenever removing or installing parts. The battery should be disconnected.
    • Disconnect the battery cable from the system board.
  4. Use the Phillips #1 screwdriver to remove the single M2x25 screw that secures the solid-state drive. Slide the SSD out from the socket to remove it from the system. Always hold the SSD at the edges.
    • Use the Phillips #1 screwdriver to remove the single M2x25 screw that secures the solid-state drive.
    • Slide the SSD out from the socket to remove it from the system.
    • Always hold the SSD at the edges.
  5. Slide the M.2 2280 solid state drive into the M.2 card slot 2. Slide the M.2 2280 thermal shield onto the frame. Use the Phillips #1 screwdriver to replace the M2x25 screw and secure the SSD.
    • Slide the M.2 2280 solid state drive into the M.2 card slot 2.
    • Slide the M.2 2280 thermal shield onto the frame.
    • Use the Phillips #1 screwdriver to replace the M2x25 screw and secure the SSD.
  6. To mount the solid state drive to primary drive go to the disk management setting. Right-click the unallocated drive and then left-click on the new simple volume. You will get prompted with 5 screens: Welcome to the New Simple Volume Wizards:  Press “Next".
    • To mount the solid state drive to primary drive go to the disk management setting. Right-click the unallocated drive and then left-click on the new simple volume.
    • You will get prompted with 5 screens:
    • Welcome to the New Simple Volume Wizards: Press “Next".
    • Specify Volume size: Choose the amount of memory you want to allocate (1000Mb = 1GB). Then click “Next”.
  7. Assign Driver Letter or Path: Choose “Mount in the following empty NFTS folder” by clicking browse. Now choose what drive to mount to by clicking the drive, it will enable a drop-down list. Find the location on the drive that you find suitable. Then make an empty folder or place it into an empty folder. Then press “OK” then “Next”.
    • Assign Driver Letter or Path: Choose “Mount in the following empty NFTS folder” by clicking browse.
    • Now choose what drive to mount to by clicking the drive, it will enable a drop-down list.
    • Find the location on the drive that you find suitable. Then make an empty folder or place it into an empty folder. Then press “OK” then “Next”.
    • Make sure that the “Format this volume with the following settings” option is selected with default settings then click “Next”.
    • To complete the new simple volume wizard, click finish.
終わりに
To reassemble your device, follow step 3 in reverse order until step 1.
Rachad Quintyne
メンバー登録日: 2021年07月03日
195 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G19, Melo-Thaiss Summer 2021 York University, Team S2-G19, Melo-Thaiss Summer 2021人のメンバー
YORK-MELO-THAISS-SU21S2G19
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 44
