メインコンテンツにスキップ
Alienware M14xR2 Hard Drive Replacement
必要な工具と部品
  1. Alienware M14xR2 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Hard Drive Replacement: 手順 2、 3の画像 1 Alienware M14xR2 Hard Drive Replacement: 手順 2、 3の画像 2 Alienware M14xR2 Hard Drive Replacement: 手順 2、 3の画像 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Hard Drive Replacement: 手順 3、 1の画像 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Hard Drive Replacement: 手順 4、 3の画像 1 Alienware M14xR2 Hard Drive Replacement: 手順 4、 3の画像 2 Alienware M14xR2 Hard Drive Replacement: 手順 4、 3の画像 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Hard Drive Replacement, Optical Drive: 手順 5、 3の画像 1 Alienware M14xR2 Hard Drive Replacement, Optical Drive: 手順 5、 3の画像 2 Alienware M14xR2 Hard Drive Replacement, Optical Drive: 手順 5、 3の画像 3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
  6. Alienware M14xR2 Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 1 Alienware M14xR2 Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 2
    • Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
    • The screws are spring loaded and will not come loose from the hard drive assembly.
    • Pull up on the black tab gently as there is still a cable attaching the hard drive to the computer.
  7. Alienware M14xR2 Hard Drive Replacement: 手順 7、 2の画像 1 Alienware M14xR2 Hard Drive Replacement: 手順 7、 2の画像 2
    • Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it.
    • Set aside the now disconnected hard drive.
終わりに
5 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Connor Bovee
メンバー登録日: 09/30/13
569 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S13G4
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 11,067
