Turn the computer off.
Disconnect the charging cable from the computer.
Failure to unplug the charging cable could result in electric shock and serious injury.
Flip the computer upside down.
Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
The two screws are spring loaded and will not separate from the cover.
Slide the back cover towards you and then lift upwards to remove.
Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
Pull up on the white connector to disconnect it from the laptop.
The battery is now free to remove from the laptop and can be set aside.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
