メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alienware M11xR2 Display Assembly Replacement
必要な工具と部品
  1. Alienware M11xR2 Display Assembly Replacement, Disconnecting Antenna Cable: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the antenna cables from the Mini-Card(s).
  2. Alienware M11xR2 Display Assembly Replacement, Removing Mimi Card: 手順 2、 1の画像 1
    • The routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
  3. Alienware M11xR2 Display Assembly Replacement, Turning Over The Computer: 手順 3、 1の画像 1
    • Turn the computer over and open the display as far as possible.
  4. Alienware M11xR2 Display Assembly Replacement, Pulling The Pull-Tab: 手順 4、 1の画像 1
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  5. Alienware M11xR2 Display Assembly Replacement, Removing Screws: 手順 5、 1の画像 1
    • Remove the four screws that secure the display assembly to the computer base.
  6. Alienware M11xR2 Display Assembly Replacement, Removing Mini-Card cable: 手順 6、 1の画像 1
    • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
  7. Alienware M11xR2 Display Assembly Replacement, Lifting Display Assembly: 手順 7、 1の画像 1
    • Lift the display assembly off the computer.
  8. Alienware M11xR2 Display Assembly Replacement, Sliding New Cables: 手順 8、 1の画像 1
    • Slide the antenna cables in through the slot on the computer base.
  9. Alienware M11xR2 Display Assembly Replacement, Securing Screws: 手順 9、 1の画像 1
    • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  10. Alienware M11xR2 Display Assembly Replacement, Connecting New Display Cable: 手順 10、 1の画像 1
    • Connect the display cable to the connector on the system board.
  11. Alienware M11xR2 Display Assembly Replacement, Rerouting  The Mini-Card Cable: 手順 11、 1の画像 1
    • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
  12. Alienware M11xR2 Display Assembly Replacement, Connecting Mini-Card Cables: 手順 12、 1の画像 1
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
ゴール
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
darrius
メンバー登録日: 03/26/18
5,213 ポイント
30のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
44 メンバー
1,996のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 666
