メインコンテンツにスキップ
Alienware Aurora M9700 Hard Drive Replacement
必要な工具と部品
  1. Alienware Aurora M9700 Hard Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • Turn laptop upside down so you're looking at the bottom side of the laptop.
  2. Alienware Aurora M9700 Hard Drive Replacement: 手順 2、 3の画像 1 Alienware Aurora M9700 Hard Drive Replacement: 手順 2、 3の画像 2 Alienware Aurora M9700 Hard Drive Replacement: 手順 2、 3の画像 3
    • At the bottom left corner, locate the square battery pack with the sliding unlock emblem above it.
    • Slide the lock to the right to unlock the battery pack.
    • Once it's unlocked the battery will release.
    • Lift the battery, removing it from its compartment.
  3. Alienware Aurora M9700 Hard Drive Replacement: 手順 3、 3の画像 1 Alienware Aurora M9700 Hard Drive Replacement: 手順 3、 3の画像 2 Alienware Aurora M9700 Hard Drive Replacement: 手順 3、 3の画像 3
    • At the bottom right corner, locate the two hard drives labeled 1 and 2.
    • Remove the screws located on top of the hard drives slots.
    • Once screws are removed from each hard drive, slide both hard drives out of the slot.
  4. Alienware Aurora M9700 Hard Drive Replacement: 手順 4、 3の画像 1 Alienware Aurora M9700 Hard Drive Replacement: 手順 4、 3の画像 2 Alienware Aurora M9700 Hard Drive Replacement: 手順 4、 3の画像 3
    • Each hard drive is attached to a cover which contains 4 screws located on all 4 corners of the hard drive.
    • Remove each of the 4 screws on both hard drive covers.
    • Once both covers are removed only the original hard drive will remain.
  5. Alienware Aurora M9700 Hard Drive Replacement: 手順 5、 3の画像 1 Alienware Aurora M9700 Hard Drive Replacement: 手順 5、 3の画像 2 Alienware Aurora M9700 Hard Drive Replacement: 手順 5、 3の画像 3
    • Secure the new hard drive to the original hard drive cover, insert the screws on all 4 corners of the hard drive cover.
    • Complete this process for both hard drives. (Optional: if installing two drives.)
終わりに
作成者
4人の作成者と共同で作成されました。
Jasmine Anchondo
メンバー登録日: 10/09/18
679 ポイント
5のガイドは作成済み
チーム
Sam Houston State, Team S15-G3, Blackburne Fall 2018 Sam Houston State, Team S15-G3, Blackburne Fall 2018人のメンバー
SHSU-BLACKBURNE-F18S15G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 411
