メインコンテンツにスキップ
Alienware 17 R4 Solid State Drive (SSD) Replacement
必要な工具と部品
  1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: 手順 1、 1の画像 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 2、 2の画像 1 Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 2、 2の画像 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): 手順 3、 3の画像 1 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): 手順 3、 3の画像 2 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): 手順 3、 3の画像 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 4、 3の画像 1 Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 4、 3の画像 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 4、 3の画像 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 5、 3の画像 1 Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 5、 3の画像 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 5、 3の画像 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 6、 2の画像 1 Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 6、 2の画像 2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: 手順 7、 2の画像 1 Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: 手順 7、 2の画像 2
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  8. Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 8、 2の画像 1 Alienware 17 R4 Solid State Drive (SSD) Replacement: 手順 8、 2の画像 2
    • Slide the solid state drive towards yourself to prevent damage to the card.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Hector Mendez III
メンバー登録日: 09/11/17
1,352 ポイント
8のガイドは作成済み
チーム
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G4
4 メンバー
9のガイドは作成済み
1件のガイドコメント
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 41
今までの合計 7,357
