メインコンテンツにスキップ
Alienware 17 R4 Front Speakers Replacement
必要な工具と部品
  1. Alienware 17 R4 Front Speakers Replacement, Base Cover: 手順 1、 1の画像 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Front Speakers Replacement: 手順 2、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 2、 2の画像 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Front Speakers Replacement, Hard Disk Drive (HDD): 手順 3、 3の画像 1 Alienware 17 R4 Front Speakers Replacement, Hard Disk Drive (HDD): 手順 3、 3の画像 2 Alienware 17 R4 Front Speakers Replacement, Hard Disk Drive (HDD): 手順 3、 3の画像 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Front Speakers Replacement: 手順 4、 3の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 4、 3の画像 2 Alienware 17 R4 Front Speakers Replacement: 手順 4、 3の画像 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Front Speakers Replacement: 手順 5、 3の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 5、 3の画像 2 Alienware 17 R4 Front Speakers Replacement: 手順 5、 3の画像 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Front Speakers Replacement: 手順 6、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 6、 2の画像 2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Front Speakers Replacement, RAM: 手順 7、 3の画像 1 Alienware 17 R4 Front Speakers Replacement, RAM: 手順 7、 3の画像 2 Alienware 17 R4 Front Speakers Replacement, RAM: 手順 7、 3の画像 3
    • Move the metal sidings outward to release the RAM card.
  8. Alienware 17 R4 Front Speakers Replacement: 手順 8、 1の画像 1
    • Slide the RAM card out towards yourself to remove it.
    • Repeat the same step for the RAM card above.
    • Slide the RAM card out carefully to avoid damaging it.
  9. Alienware 17 R4 Front Speakers Replacement, Wi-Fi card: 手順 9、 1の画像 1
    • Locate the WI-FI card.
  10. Alienware 17 R4 Front Speakers Replacement: 手順 10、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 10、 2の画像 2
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  11. Alienware 17 R4 Front Speakers Replacement: 手順 11、 3の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 11、 3の画像 2 Alienware 17 R4 Front Speakers Replacement: 手順 11、 3の画像 3
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  12. Alienware 17 R4 Front Speakers Replacement: 手順 12、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 12、 2の画像 2
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
  13. Alienware 17 R4 Front Speakers Replacement, Solid State Drive: 手順 13、 2の画像 1 Alienware 17 R4 Front Speakers Replacement, Solid State Drive: 手順 13、 2の画像 2
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  14. Alienware 17 R4 Front Speakers Replacement: 手順 14、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 14、 2の画像 2
    • Slide the solid state drive towards yourself to prevent damage to the card.
  15. Alienware 17 R4 Front Speakers Replacement, Fan Shroud: 手順 15、 3の画像 1 Alienware 17 R4 Front Speakers Replacement, Fan Shroud: 手順 15、 3の画像 2 Alienware 17 R4 Front Speakers Replacement, Fan Shroud: 手順 15、 3の画像 3
    • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
  16. Alienware 17 R4 Front Speakers Replacement: 手順 16、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 16、 2の画像 2
    • Insert the plastic opening tool under the fan shroud to slowly lift it up.
    • Repeat process on the middle and opposite side.
  17. Alienware 17 R4 Front Speakers Replacement: 手順 17、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 17、 2の画像 2
    • Firmly lift the plastic opening tool and pull the fan shroud towards you.
    • This will take a large amount of force and will not come out easily the first time.
    • Careful not to tear out the piece causing damage to the fan shroud
  18. Alienware 17 R4 Front Speakers Replacement, Plastic Cover: 手順 18、 3の画像 1 Alienware 17 R4 Front Speakers Replacement, Plastic Cover: 手順 18、 3の画像 2 Alienware 17 R4 Front Speakers Replacement, Plastic Cover: 手順 18、 3の画像 3
    • Unscrew the two M2x3 screws (1.9 mm) at the top right and top left of the laptop that hold the tron lights in place.
  19. Alienware 17 R4 Front Speakers Replacement: 手順 19、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 19、 2の画像 2
    • Follow the wiring to unplug the tron lights.
  20. Alienware 17 R4 Front Speakers Replacement: 手順 20、 3の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 20、 3の画像 2 Alienware 17 R4 Front Speakers Replacement: 手順 20、 3の画像 3
    • Remove the fourteen M2.5XL8' screws (2.4 mm) located in the plastic cover using the PH1 screwdriver.
  21. Alienware 17 R4 Front Speakers Replacement: 手順 21、 1の画像 1
    • Use the plastic opening tool to gently lift the sides of the cover.
  22. Alienware 17 R4 Front Speakers Replacement: 手順 22、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 22、 2の画像 2
    • Slowly lift up the plastic cover.
  23. Alienware 17 R4 Front Speakers Replacement, Battery: 手順 23、 3の画像 1 Alienware 17 R4 Front Speakers Replacement, Battery: 手順 23、 3の画像 2 Alienware 17 R4 Front Speakers Replacement, Battery: 手順 23、 3の画像 3
    • Unscrew the four M2.5 screws (2.4 mm) with a PH1 screwdriver bit.
  24. Alienware 17 R4 Front Speakers Replacement: 手順 24、 2の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 24、 2の画像 2
    • Lift the battery up to remove it.
  25. Alienware 17 R4 Front Speakers Replacement, Front Speakers: 手順 25、 2の画像 1 Alienware 17 R4 Front Speakers Replacement, Front Speakers: 手順 25、 2の画像 2
    • Unplug the wire that connects the front speakers to the laptop.
  26. Alienware 17 R4 Front Speakers Replacement: 手順 26、 3の画像 1 Alienware 17 R4 Front Speakers Replacement: 手順 26、 3の画像 2 Alienware 17 R4 Front Speakers Replacement: 手順 26、 3の画像 3
    • Gently lift up the front speakers.
    • The speaker does not have screws holding it in place.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Hector Mendez III
メンバー登録日: 09/11/17
1,280 ポイント
8のガイドは作成済み
チーム
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G4
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 3,730
