はじめに
In order to access any other laptop parts for replacements, the fan shroud will need to be removed before the plastic cover shielding the interior. This guide will show you how to remove the fan shroud.
必要な工具と部品
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
3 の人々がこのガイドを完成させました。
